简介
This guide will give you step by step instructions to removing your Dell Inspiron 13-7359 laptop speaker. You will need a phillips head #0 screwdriver and a plastic spudger.
你所需要的
First flip over the laptop to expose the back panel
Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
Following the removal of the Battery, remove the left speaker.
As you lift the left speaker, carefully lift the wire that connects the left and right speakers.
另外一个人完成了本指南。
