跳转到主内容
Dell Inspiron 13-7359 Speaker Replacement
你所需要的
  1. Dell Inspiron 13-7359 Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. Dell Inspiron 13-7359 Speaker Replacement: 步骤 2 中的图像 1,1
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. Dell Inspiron 13-7359 Speaker Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 13-7359 Speaker Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 13-7359 Speaker Replacement: 步骤 3 中的图像 3,3
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. Dell Inspiron 13-7359 Speaker Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 13-7359 Speaker Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 13-7359 Speaker Replacement: 步骤 4 中的图像 3,3
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
  5. Dell Inspiron 13-7359 Speaker Replacement, Speaker: 步骤 5 中的图像 1,2 Dell Inspiron 13-7359 Speaker Replacement, Speaker: 步骤 5 中的图像 2,2
    • Following the removal of the Battery, remove the left speaker.
    • As you lift the left speaker, carefully lift the wire that connects the left and right speakers.
  6. Dell Inspiron 13-7359 Speaker Replacement: 步骤 6 中的图像 1,2 Dell Inspiron 13-7359 Speaker Replacement: 步骤 6 中的图像 2,2
    • Disconnect the small wires attached to the top of the right side speaker as marked in the photo.
  7. Dell Inspiron 13-7359 Speaker Replacement: 步骤 7 中的图像 1,2 Dell Inspiron 13-7359 Speaker Replacement: 步骤 7 中的图像 2,2
    • Use the plastic spudger to safely and easily detach the right speaker from the device.
    • Lift the right speaker out to complete the removal.
结论
另外一个人完成了本指南。
Katie Ragsdale
于01/30/18注册
192 声望
撰写一个指南
团队
Baylor, Team S1-G6, Johnson Spring 2018 Baylor, Team S1-G6, Johnson Spring 2018 的会员
BU-JOHNSON-S18S1G6
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 384
