跳转到主内容
Dell Inspiron 13-7359 Cooling Fan Replacement
你所需要的
  1. Dell Inspiron 13-7359 Cooling Fan Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Flip your device over so the back cover is facing you.
    • Using a Phillips #0 Screwdriver, remove the ten 7mm screws holding the back cover in place.
  2. Dell Inspiron 13-7359 Cooling Fan Replacement: 步骤 2 中的图像 1,1
    • Insert a plastic opening and run it along the edge of the back cover. Do this until the entire back cover can be removed.
  3. Dell Inspiron 13-7359 Cooling Fan Replacement, Cooling Fan: 步骤 3 中的图像 1,2 Dell Inspiron 13-7359 Cooling Fan Replacement, Cooling Fan: 步骤 3 中的图像 2,2
    • Unscrew and remove the 2 of the 7mm Phillips head screws holding the cooling fan in place.
  4. Dell Inspiron 13-7359 Cooling Fan Replacement: 步骤 4 中的图像 1,1
    • Hold the cooling fan with one hand.
    • With the other hand, grab hold of the part of the copper heat sink that is attached to the cooling fan.
    • Carefully pull the cooling fan away from the attached part so that it becomes fully disconnected.
结论
2等其他人完成本指南。
Valentin Medina
于01/30/18注册
697 声望
创作了3篇指南
团队
Baylor, Team S1-G6, Johnson Spring 2018 Baylor, Team S1-G6, Johnson Spring 2018 的会员
BU-JOHNSON-S18S1G6
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 19
总计 658
