跳转到主内容
Dell Inspiron 13-7359 Battery Replacement
你所需要的
  1. Dell Inspiron 13-7359 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. Dell Inspiron 13-7359 Battery Replacement: 步骤 2 中的图像 1,1
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. Dell Inspiron 13-7359 Battery Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 13-7359 Battery Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 13-7359 Battery Replacement: 步骤 3 中的图像 3,3
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. Dell Inspiron 13-7359 Battery Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 13-7359 Battery Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 13-7359 Battery Replacement: 步骤 4 中的图像 3,3
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
结论
4等其他人完成本指南。
Valentin Medina
于01/30/18注册
697 声望
创作了3篇指南
团队
Baylor, Team S1-G6, Johnson Spring 2018 Baylor, Team S1-G6, Johnson Spring 2018 的会员
BU-JOHNSON-S18S1G6
3 名成员
创作了5篇指南
一条评论
thanks for this, my daughter’s laptop now needs a new battery and while I assumed it would be easy, it’s good to get a preview.
Paul M - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,593
