跳转到主内容
Dell Inspiron 13-7353 Hard Drive Replacement
你所需要的
  1. Dell Inspiron 13-7353 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Using the Phillips #0 screwdriver, remove ten 4 mm screws from the back panel.
    • Lift and remove the back panel.
  2. Dell Inspiron 13-7353 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery to the laptop.
  3. Dell Inspiron 13-7353 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Remove the battery up and out of the computer.
  4. Dell Inspiron 13-7353 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • Unplug the hard drive cable from the motherboard.
  5. Dell Inspiron 13-7353 Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Using the Phillips #000 screwdriver, remove two 3mm screws from the hard drive frame.
  6. Dell Inspiron 13-7353 Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Lift the hard drive up and out of the computer.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 799
