跳转到主内容
Dell Inspiron 13-7353 Fan Replacement
你所需要的
  1. Dell Inspiron 13-7353 Fan Replacement, Flip the Computer: 步骤 1 中的图像 1,1
    • WARNING: Please read the safety information shipped with your computer and follow recommended steps before working inside your computer. When finished working inside your computer, follow the instructions included in the safety information.
    • Close the computer display and turn the computer over so that the base of the computer is facing up.
  2. Dell Inspiron 13-7353 Fan Replacement, Secure the Base: 步骤 2 中的图像 1,1
    • Remove the ten screws that secure the base cover to the base of the computer.
  3. Dell Inspiron 13-7353 Fan Replacement, Pry the Base cover: 步骤 3 中的图像 1,1
    • Using a plastic scribe (plastic opening tool), pry the base cover off of the base of the computer.
  4. Dell Inspiron 13-7353 Fan Replacement, RAM: 步骤 4 中的图像 1,2 Dell Inspiron 13-7353 Fan Replacement, RAM: 步骤 4 中的图像 2,2
    • Before opening your device, ensure that all data is backed up on a hard drive to prevent data loss.
    • Loosen and then unplug the hard drive cable.
  5. Dell Inspiron 13-7353 Fan Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 13-7353 Fan Replacement: 步骤 5 中的图像 2,2
    • Remove the two M2 3mm screws attaching the battery using the Phillips #1 screwdriver.
    • Remove the battery.
  6. Dell Inspiron 13-7353 Fan Replacement: 步骤 6 中的图像 1,3 Dell Inspiron 13-7353 Fan Replacement: 步骤 6 中的图像 2,3 Dell Inspiron 13-7353 Fan Replacement: 步骤 6 中的图像 3,3
    • Pry open the two clips.
    • Gently lift the RAM stick and pull it out of the motherboard.
  7. Dell Inspiron 13-7353 Fan Replacement, Fan: 步骤 7 中的图像 1,3 Dell Inspiron 13-7353 Fan Replacement, Fan: 步骤 7 中的图像 2,3 Dell Inspiron 13-7353 Fan Replacement, Fan: 步骤 7 中的图像 3,3
    • Unplug the daughterboard cable in two places, then remove the daughterboard.
    • Unplug the fan cable.
  8. Dell Inspiron 13-7353 Fan Replacement: 步骤 8 中的图像 1,2 Dell Inspiron 13-7353 Fan Replacement: 步骤 8 中的图像 2,2
    • Remove two 3mm screws from the cooling fan using the Phillips #1 screwdriver.
    • Remove the cooling fan from the laptop.
结论
2等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 8
总计 744
