跳转到主内容
Dell Inspiron 13-7353 Battery Replacement
你所需要的
  1. Dell Inspiron 13-7353 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Using the Phillips #0 screwdriver, remove ten 4 mm screws from the back panel.
    • Lift and remove the back panel.
  2. Dell Inspiron 13-7353 Battery Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery to the laptop.
  3. Dell Inspiron 13-7353 Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the battery up and out of the computer.
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 22
总计 1,134
