跳转到主内容
Dell Inspiron 13-7352 DC POWER JACK HARNESS Replacement
你所需要的
  1. Dell Inspiron 13-7352 DC POWER JACK HARNESS  Replacement, Back Panel Removal: 步骤 1 中的图像 1,3 Dell Inspiron 13-7352 DC POWER JACK HARNESS  Replacement, Back Panel Removal: 步骤 1 中的图像 2,3 Dell Inspiron 13-7352 DC POWER JACK HARNESS  Replacement, Back Panel Removal: 步骤 1 中的图像 3,3
    • Before disassembling your laptop, be sure it is powered off.
    • Remove the ten 7.5mm screws that secure the back panel with the Phillips #0 head
    • Use the plastic opening tool to remove the back panel. Start at the back corner and work across. The front edge of the laptop panel hinges and pivots upward after the back edge and the side edges are separated from the casing.
  2. Dell Inspiron 13-7352 DC POWER JACK HARNESS  Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 13-7352 DC POWER JACK HARNESS  Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 13-7352 DC POWER JACK HARNESS  Replacement: 步骤 2 中的图像 3,3
    • Remove the one 4mm screw with the Phillips #0 head that hold down the battery.
    • Use the plastic opening tool to remove DC Power Jack harness connector from the motherboard.
    • Gently remove the DC power jack harness from the device and replace it with a new one.
结论
另外一个人完成了本指南。
Anthony Burke
于03/08/15注册
109 声望
撰写一个指南
团队
MWP Supply, Inc. MWP Supply, Inc. 的会员
Business
1 名成员
创作了1篇指南
一条评论
This is perfect, but I’m curious how others may have handled an issue where the screw hole for my 7359’s power jack disintegrated. Anyone have any idea on how to anchor a power jack without that screw hole? I tried Sugru to mold around it, but that didn’t work. Any other ideas would be welcome.
Harry Morgan - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 20
总计 866
