跳转到主内容
Dell Inspiron 13-5378 Display Assembly Replacement
你所需要的
  1. Dell Inspiron 13-5378 Display Assembly Replacement, Peeling the Tape: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Peel off the pieces of tape that secure the display cable and touch-screen board-cable to the system board.
  2. Dell Inspiron 13-5378 Display Assembly Replacement, Open the Latches: 步骤 2 中的图像 1,1
    • Open the latches to disconnect the display cable and the touch-screen board-cable from the system board.
  3. Dell Inspiron 13-5378 Display Assembly Replacement, Open the Display: 步骤 3 中的图像 1,1
    • Turn the computer over and open the display as far as possible.
  4. Dell Inspiron 13-5378 Display Assembly Replacement, Placing the Computer: 步骤 4 中的图像 1,1
    • CAUTION: Place the computer on a soft and clean surface to avoid scratching the display.
    • Place the computer face down on a flat surface.
  5. Dell Inspiron 13-5378 Display Assembly Replacement, Remove the Screws: 步骤 5 中的图像 1,1
    • Remove the screws that secure the display assembly to the palm-rest assembly.
  6. Dell Inspiron 13-5378 Display Assembly Replacement, Lifting the Display Assembly: 步骤 6 中的图像 1,1
    • Lift the display assembly off the palm-rest assembly.
  7. Dell Inspiron 13-5378 Display Assembly Replacement, Placing the Display Assembly: 步骤 7 中的图像 1,1
    • Place the NEW display assembly face down on the palm-rest assembly.
  8. Dell Inspiron 13-5378 Display Assembly Replacement, Align the Screw Holes: 步骤 8 中的图像 1,1
    • Align the screw holes on the display hinges with the screw holes on the palm-rest assembly.
    • Close the display and turn the computer over.
  9. Dell Inspiron 13-5378 Display Assembly Replacement, Sliding the Display Cable: 步骤 10 中的图像 1,2 Dell Inspiron 13-5378 Display Assembly Replacement, Sliding the Display Cable: 步骤 10 中的图像 2,2
    • Slide the display cable and the touch-screen board-cable into their respective connectors on the system board and close the latches to secure the cables.
  10. Dell Inspiron 13-5378 Display Assembly Replacement, Adhering the Pieces: 步骤 11 中的图像 1,1
    • Adhere the pieces of tape that secure the display cable and the touch-screen board-cable to their respective connectors on the system board.
结论
Terrence15
于12/18/17注册
79,243 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,989篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 28
总计 3,315
