当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
Use a spudger to pry up and remove the back cover.
Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
Pull the tab parallel to the motherboard, not straight up.
Remove the battery.
Unscrew the 2mm screw that holds the WLAN card. Then carefully remove the WLAN card from the motherboard.
Detach the black and white antenna cables from the WLAN card.
Unplug the two display cables.
Unscrew the screws that are securing the laptop's hinges.
Detach the display from the base.
取消:我没有完成这个指南。
2等其他人完成本指南。
与1其他贡献者
于09/27/17注册
1,042 声望
创作了6篇指南
徽章: 13
+ 10更多徽章
USFT-BOCZAR-F17S14G6
4 名成员
创作了13篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 18
总计 2,142
