跳转到主内容
Dell Inspiron 13-5368 Screen Display Replacement
你所需要的
  1. Dell Inspiron 13-5368 Screen Display Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron 13-5368 Screen Display Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
  2. Dell Inspiron 13-5368 Screen Display Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 13-5368 Screen Display Replacement: 步骤 2 中的图像 2,2
    • Use a spudger to pry up and remove the back cover.
  3. Dell Inspiron 13-5368 Screen Display Replacement: 步骤 3 中的图像 1,1
    • Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
  4. Dell Inspiron 13-5368 Screen Display Replacement: 步骤 4 中的图像 1,1
    • Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
    • Pull the tab parallel to the motherboard, not straight up.
  5. Dell Inspiron 13-5368 Screen Display Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 13-5368 Screen Display Replacement: 步骤 5 中的图像 2,2
    • Remove the battery.
  6. Dell Inspiron 13-5368 Screen Display Replacement, Screen Display: 步骤 6 中的图像 1,3 Dell Inspiron 13-5368 Screen Display Replacement, Screen Display: 步骤 6 中的图像 2,3 Dell Inspiron 13-5368 Screen Display Replacement, Screen Display: 步骤 6 中的图像 3,3
    • Unscrew the 2mm screw that holds the WLAN card. Then carefully remove the WLAN card from the motherboard.
  7. Dell Inspiron 13-5368 Screen Display Replacement: 步骤 7 中的图像 1,1
    • Detach the black and white antenna cables from the WLAN card.
  8. Dell Inspiron 13-5368 Screen Display Replacement: 步骤 8 中的图像 1,1
    • Unplug the two display cables.
  9. Dell Inspiron 13-5368 Screen Display Replacement: 步骤 9 中的图像 1,1
    • Unscrew the screws that are securing the laptop's hinges.
  10. Dell Inspiron 13-5368 Screen Display Replacement: 步骤 10 中的图像 1,1
    • Detach the display from the base.
结论
2等其他人完成本指南。
Matt Sugrim
于09/27/17注册
1,042 声望
创作了6篇指南
团队
USF Tampa, Team S14-G6, Boczar Fall 2017 USF Tampa, Team S14-G6, Boczar Fall 2017 的会员
USFT-BOCZAR-F17S14G6
4 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 18
总计 2,183
