跳转到主内容
Dell Inspiron 13-5368 Heatsink Replacement
你所需要的
  1. Dell Inspiron 13-5368 Heatsink Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron 13-5368 Heatsink Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
  2. Dell Inspiron 13-5368 Heatsink Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 13-5368 Heatsink Replacement: 步骤 2 中的图像 2,2
    • Use a spudger to pry up and remove the back cover.
  3. Dell Inspiron 13-5368 Heatsink Replacement: 步骤 3 中的图像 1,1
    • Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
  4. Dell Inspiron 13-5368 Heatsink Replacement: 步骤 4 中的图像 1,1
    • Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
    • Pull the tab parallel to the motherboard, not straight up.
  5. Dell Inspiron 13-5368 Heatsink Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 13-5368 Heatsink Replacement: 步骤 5 中的图像 2,2
    • Remove the battery.
  6. Dell Inspiron 13-5368 Heatsink Replacement, Heatsink: 步骤 6 中的图像 1,2 Dell Inspiron 13-5368 Heatsink Replacement, Heatsink: 步骤 6 中的图像 2,2
    • Unscrew the four screws securing the heatsink and remove it.
    • Remember to reapply a small amount of thermal paste, then screw the heatsink onto the motherboard in numberical order (i.e. 1, 2, 3, 4).
结论
Remember to clean off any old thermal paste, then apply a small amount of new thermal paste (dime size will be fine). Screw the heatsink on in numerical order so the thermal paste is evenly distributed on the processor. To reassemble your device, follow these instructions in reverse order.
另外一个人完成了本指南。
Matt Sugrim
于09/27/17注册
1,042 声望
创作了6篇指南
团队
USF Tampa, Team S14-G6, Boczar Fall 2017 USF Tampa, Team S14-G6, Boczar Fall 2017 的会员
USFT-BOCZAR-F17S14G6
4 名成员
创作了13篇指南
一条评论
Is it normal for the heatsink to be loose right in front of the fan? The black part of the heatsink?
JRaje - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 695
