跳转到主内容
Dell Inspiron 13 7378 Wi-Fi Card Replacement
你所需要的
  1. Dell Inspiron 13 7378 Wi-Fi Card Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Set the laptop with its underside facing up for improved accessibility.
  2. Dell Inspiron 13 7378 Wi-Fi Card Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 13 7378 Wi-Fi Card Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #00 screwdriver, extract the nine 3 mm screws located on the back of the laptop.
  3. Dell Inspiron 13 7378 Wi-Fi Card Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 13 7378 Wi-Fi Card Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 13 7378 Wi-Fi Card Replacement: 步骤 3 中的图像 3,3
    • Carefully pry open the back of the back of the laptop using opening picks.
    • Carefully raise and detach the back cover from the laptop.
    • Exercise caution to prevent damaging or cracking the device's back cover.
  4. Dell Inspiron 13 7378 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 4 中的图像 1,2 Dell Inspiron 13 7378 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 4 中的图像 2,2
    • Remove the single 3 mm screw from the Wi-Fi card using a Phillips #1 screwdriver.
  5. Dell Inspiron 13 7378 Wi-Fi Card Replacement: 步骤 5 中的图像 1,1
    • Use your fingers to pull the Wi-Fi card upwards from the slot of the motherboard.
    • Take caution in pulling out the Wi-Fi card; two cable connectors are still attached.
  6. Dell Inspiron 13 7378 Wi-Fi Card Replacement: 步骤 6 中的图像 1,1
    • Disconnect the two wires attached to the Wi-Fi card.
    • Remove the Wi-Fi card from the laptop.
结论
另外一个人完成了本指南。
团队
Gateway, Team 1-3, Saknee Spring 2022 Gateway, Team 1-3, Saknee Spring 2022 的会员
GCC-SAKNEE-S22S1G3
5 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 31
总计 382
