跳转到主内容
Dell Inspiron 13 7368 Memory Modules Replacement
你所需要的
  1. Dell Inspiron 13 7368 Memory Modules Replacement, Disconnecting the Battery Cable: 步骤 1 中的图像 1,1
  2. Dell Inspiron 13 7368 Memory Modules Replacement, Remove the Screws: 步骤 2 中的图像 1,1
    • Remove the screws that secure the battery to the palm-rest assembly.
  3. Dell Inspiron 13 7368 Memory Modules Replacement, Lifting the Battery: 步骤 3 中的图像 1,1
    • Lift the battery off the palm-rest assembly.
    • Press and hold the power button for five seconds to ground the system board.
  4. Dell Inspiron 13 7368 Memory Modules Replacement, Align the Screw Holes: 步骤 5 中的图像 1,1
    • Align the screw holes on the battery with the screw holes on the palm-rest assembly.
  5. Dell Inspiron 13 7368 Memory Modules Replacement, Replace the Screws: 步骤 6 中的图像 1,1
    • Replace the screws that secure the battery to the palm-rest assembly.
  6. Dell Inspiron 13 7368 Memory Modules Replacement, Connecting the Battery Cable: 步骤 7 中的图像 1,1
    • Connect the battery cable to the system board.
  7. Dell Inspiron 13 7368 Memory Modules Replacement, Lifting the Mylar: 步骤 8 中的图像 1,1
  8. Dell Inspiron 13 7368 Memory Modules Replacement, Popping up the Memory Module: 步骤 9 中的图像 1,1
    • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
  9. Dell Inspiron 13 7368 Memory Modules Replacement, Removing the Memory Module: 步骤 10 中的图像 1,2 Dell Inspiron 13 7368 Memory Modules Replacement, Removing the Memory Module: 步骤 10 中的图像 2,2
    • Remove the memory module from the memory-module slot.
  10. Dell Inspiron 13 7368 Memory Modules Replacement, Lifting the Mylar: 步骤 11 中的图像 1,1
    • Lift the Mylar to access the memory-module slot.
  11. Dell Inspiron 13 7368 Memory Modules Replacement, Align the Notch: 步骤 12 中的图像 1,1
    • Align the notch on the memory module with the tab on the memory-module slot.
  12. Dell Inspiron 13 7368 Memory Modules Replacement, Sliding the Memory Module: 步骤 13 中的图像 1,1
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
终点
Terrence15
于12/18/17注册
79,091 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 430
