跳转到主内容
简介
In this guide, we will be showing you how to remove and replace the Hard Drive.
配件
没有特定配件。
  1. Follow the procedures in Before You Begin.
    • Follow the procedures in Before You Begin.
    • Remove the module cover (see Base Cover).
  2. NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips. Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up. Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
  3. Macbook 电池维修套装
    起价 $69.99
    Buy Now
    Macbook 电池维修套装
    起价 $69.99
    Buy Now
  4. Remove the module from the connector.
    • Remove the module from the connector.
  5. Align the notch in the module edge connector with the tab in the connector slot. Align the notch in the module edge connector with the tab in the connector slot.
    • Align the notch in the module edge connector with the tab in the connector slot.
  6. Slide the NEW module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If the module does not click into place, remove the module and reinstall it.
    • Slide the NEW module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If the module does not click into place, remove the module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
终点
Terrence15
于2017年12月18日注册
70,933 信誉积分
创作了442篇指南
团队
Informative Technologies Inc. Informative Technologies Inc. 的会员
Community
15 名成员
创作了930篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 17
