跳转到主内容
Dell Inspiron 1200 Display Assembly Replacement
你所需要的
  1. Dell Inspiron 1200 Display Assembly Replacement, Disconnecting the Ground Wire: 步骤 1 中的图像 1,2 Dell Inspiron 1200 Display Assembly Replacement, Disconnecting the Ground Wire: 步骤 1 中的图像 2,2
  2. Dell Inspiron 1200 Display Assembly Replacement, Remove the Screws: 步骤 2 中的图像 1,1
    • Remove the four M2.5 x 5-mm screws (labeled "M2.5x5") that secure the EMI shield to the system board.
  3. Dell Inspiron 1200 Display Assembly Replacement, Releasing the Retention Tabs: 步骤 3 中的图像 1,1
    • Pull the EMI shield out of the computer baseby rotating the front upwards then lifting to release the retention tabs from the retention-tab slots.
  4. Dell Inspiron 1200 Display Assembly Replacement, Disconnecting the Antenna Cable: 步骤 4 中的图像 1,1
    • Disconnect the attached antenna cable from the Mini PCI card.
    • Close the display.
    • From the bottom of the computer, remove the two M2.5 x 5-mm screws labeled "D."
  5. Dell Inspiron 1200 Display Assembly Replacement, Remove the Screws: 步骤 6 中的图像 1,1
    • From the back of the computer, remove the two M2.5 x 8-mm screws labeled "D."
  6. Dell Inspiron 1200 Display Assembly Replacement, Pull the Pull-Tab: 步骤 7 中的图像 1,2 Dell Inspiron 1200 Display Assembly Replacement, Pull the Pull-Tab: 步骤 7 中的图像 2,2
    • Pull straight up on the pull-tab that is attached to the display-feed flex cable to disconnect the cable from the system board.
  7. Dell Inspiron 1200 Display Assembly Replacement, Removing the Cables: 步骤 8 中的图像 1,1
    • Carefully remove the Mini PCI card antenna cable and the display cables from their routing guides.
  8. Dell Inspiron 1200 Display Assembly Replacement, Lifting the Display Assembly: 步骤 9 中的图像 1,1
    • Lift the display assembly out of the computer base.
结论
Terrence15
于12/18/17注册
78,592 声望
创作了441篇指南
团队
Informative Technologies Inc. Informative Technologies Inc. 的会员
Community
38 名成员
创作了1,982篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 197
