跳转到主内容
Dell Inspiron 11z-1121 RAM Replacement
你所需要的
  1. Dell Inspiron 11z-1121 RAM Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron 11z-1121 RAM Replacement, Battery: 步骤 1 中的图像 2,2
    • Slide the latches outward to release the battery.
    • Pull the battery outward to remove.
    • The latches should lock in place, allowing for easy removal.
    • The battery must be removed for safety reasons when replacing other components of the laptop.
  2. Dell Inspiron 11z-1121 RAM Replacement, RAM: 步骤 2 中的图像 1,2 Dell Inspiron 11z-1121 RAM Replacement, RAM: 步骤 2 中的图像 2,2
    • With a Phillips #1, loosen the 1 mm screw attaching the access door to the laptop body
    • Using your fingers, remove the access door to expose the memory card
  3. Dell Inspiron 11z-1121 RAM Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 11z-1121 RAM Replacement: 步骤 3 中的图像 2,2
    • To access the memory card, push out the lashes on the left and the right of the memory card.
    • To remove the memory card, use your fingers to pull it out with the lashes still stretched out.
结论
团队
USF Tampa, Team 1-5, Nance Fall 2016 USF Tampa, Team 1-5, Nance Fall 2016 的会员
USFT-NANCE-F16S1G5
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 20
总计 475
