跳转到主内容
Dell Inspiron 11z-1121 Hard Drive Replacement
你所需要的
  1. Dell Inspiron 11z-1121 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron 11z-1121 Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Slide the latches outward to release the battery.
    • Pull the battery outward to remove.
    • The latches should lock in place, allowing for easy removal.
    • The battery must be removed for safety reasons when replacing other components of the laptop.
  2. Dell Inspiron 11z-1121 Hard Drive Replacement, Keyboard: 步骤 2 中的图像 1,2 Dell Inspiron 11z-1121 Hard Drive Replacement, Keyboard: 步骤 2 中的图像 2,2
    • Unscrew three black 1mm screws using the PH1 Phillips-head screwdriver on the bottom of the laptop around the battery.
  3. Dell Inspiron 11z-1121 Hard Drive Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 11z-1121 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Flip the laptop over and open it to expose the keyboard.
    • Use a plastic opening tool to pry up the keyboard, starting in the upper corner and working your way around.
    • Once the keyboard is pried up, do not remove the keyboard. There is still a ribbon attaching the keyboard to the laptop.
  4. Dell Inspiron 11z-1121 Hard Drive Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 11z-1121 Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Lift the keyboard to expose the ribbon attaching the keyboard to the laptop.
    • Flip up the black retaining flap on the ZIF connector and then pull the ribbon cable away.
    • Remove the keyboard from the laptop.
  5. Dell Inspiron 11z-1121 Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 1,1
    • The hard drive will be a silver rectangle. Slide the hard drive to the right to remove.
    • To be safe, make sure you either wear an anti-static wrist band, or rub your hands against a metal object to remove any static.
结论
2等其他人完成本指南。
Brandan Eng
于10/04/16注册
143 声望
撰写一个指南
团队
USF Tampa, Team 1-5, Nance Fall 2016 USF Tampa, Team 1-5, Nance Fall 2016 的会员
USFT-NANCE-F16S1G5
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 15
总计 1,983
