跳转到主内容
Dell Inspiron 11z-1121 Fan Replacement
你所需要的
  1. Dell Inspiron 11z-1121 Fan Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron 11z-1121 Fan Replacement, Battery: 步骤 1 中的图像 2,2
    • Slide the latches outward to release the battery.
    • Pull the battery outward to remove.
    • The latches should lock in place, allowing for easy removal.
    • The battery must be removed for safety reasons when replacing other components of the laptop.
  2. Dell Inspiron 11z-1121 Fan Replacement, Keyboard: 步骤 2 中的图像 1,2 Dell Inspiron 11z-1121 Fan Replacement, Keyboard: 步骤 2 中的图像 2,2
    • Unscrew three black 1mm screws using the PH1 Phillips-head screwdriver on the bottom of the laptop around the battery.
  3. Dell Inspiron 11z-1121 Fan Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 11z-1121 Fan Replacement: 步骤 3 中的图像 2,2
    • Flip the laptop over and open it to expose the keyboard.
    • Use a plastic opening tool to pry up the keyboard, starting in the upper corner and working your way around.
    • Once the keyboard is pried up, do not remove the keyboard. There is still a ribbon attaching the keyboard to the laptop.
  4. Dell Inspiron 11z-1121 Fan Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 11z-1121 Fan Replacement: 步骤 4 中的图像 2,2
    • Lift the keyboard to expose the ribbon attaching the keyboard to the laptop.
    • Flip up the black retaining flap on the ZIF connector and then pull the ribbon cable away.
    • Remove the keyboard from the laptop.
  5. Dell Inspiron 11z-1121 Fan Replacement, Fan: 步骤 5 中的图像 1,2 Dell Inspiron 11z-1121 Fan Replacement, Fan: 步骤 5 中的图像 2,2
    • Start by prying the outer casing of the laptop using the plastic opening tool. Start from the bottom and work your way around the edges.
  6. Dell Inspiron 11z-1121 Fan Replacement: 步骤 6 中的图像 1,2 Dell Inspiron 11z-1121 Fan Replacement: 步骤 6 中的图像 2,2
    • Remove the outer casing to expose the motherboard.
    • Remove five .75 mm screws using a PH1 screwdriver.
    • Make sure to keep track of your screws.
  7. Dell Inspiron 11z-1121 Fan Replacement: 步骤 7 中的图像 1,1
    • Remove wireless wide area network (WWAN) card by sliding it out of position.
    • Make sure the wires attached to the WWAN card are not detached when doing this step.
  8. Dell Inspiron 11z-1121 Fan Replacement: 步骤 8 中的图像 1,2 Dell Inspiron 11z-1121 Fan Replacement: 步骤 8 中的图像 2,2
    • Unscrew the two 0.9 mm screws that are holding down the screen.
    • Lift the screen up and towards yourself to detach the screen from the laptop.
  9. Dell Inspiron 11z-1121 Fan Replacement: 步骤 9 中的图像 1,1
    • Lay the screen down and pry the left corner of the plastic casing that is located behind the screen.
  10. Dell Inspiron 11z-1121 Fan Replacement: 步骤 10 中的图像 1,1
    • While holding screen, remove the motherboard by wiggling it around and pulling outwards.
    • In this step you are trying to pull the motherboard out from the VGA socket it is attached to in the back left corner of the laptop.
  11. Dell Inspiron 11z-1121 Fan Replacement: 步骤 11 中的图像 1,2 Dell Inspiron 11z-1121 Fan Replacement: 步骤 11 中的图像 2,2
    • Unscrew the two black 0.5 mm screws holding the fan in place.
    • Remove the fan by gently lifting the component upwards.
结论
Cassidy Chen
于10/04/16注册
289 声望
创作了2篇指南
团队
USF Tampa, Team 1-5, Nance Fall 2016 USF Tampa, Team 1-5, Nance Fall 2016 的会员
USFT-NANCE-F16S1G5
4 名成员
创作了5篇指南
一条评论
I see there are a few more screws on the bottom. Can't we just unscrew those and take off the bottom panel?
bluejedi - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 1,008
