跳转到主内容
Dell Inspiron 11z 1120 Memory Module Replacement
你所需要的
  1. Dell Inspiron 11z 1120 Memory Module Replacement, Loosen the Captive Screw: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Loosen the captive screw that secures the memory-module cover to the computer base.
  2. Dell Inspiron 11z 1120 Memory Module Replacement, Lifting the Memory-Module Cover: 步骤 2 中的图像 1,1
    • Lift the memory-module cover off the computer base.
  3. Dell Inspiron 11z 1120 Memory Module Replacement, Popping up the Memory Module: 步骤 3 中的图像 1,1
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  4. Dell Inspiron 11z 1120 Memory Module Replacement, Removing the Memory Module: 步骤 4 中的图像 1,2 Dell Inspiron 11z 1120 Memory Module Replacement, Removing the Memory Module: 步骤 4 中的图像 2,2
    • Remove the memory module from the memory-module connector.
  5. Dell Inspiron 11z 1120 Memory Module Replacement, Align the Notch: 步骤 5 中的图像 1,2 Dell Inspiron 11z 1120 Memory Module Replacement, Align the Notch: 步骤 5 中的图像 2,2
    • Align the notch in the memory module with the tab in the memory-module connector.
  6. Dell Inspiron 11z 1120 Memory Module Replacement, Sliding the Memory Module: 步骤 6 中的图像 1,1
    • Slide the memory module firmly into the memory-module connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
  7. Dell Inspiron 11z 1120 Memory Module Replacement, Sliding the Tabs: 步骤 7 中的图像 1,1
    • NOTE: If the memory module is not installed properly, the computer may not boot.
    • Slide the tabs on the memory-module cover into the slots on the computer base and gently press the memory-module cover into place.
  8. Dell Inspiron 11z 1120 Memory Module Replacement, Tighten the Screw: 步骤 8 中的图像 1,1
    • Tighten the screw that secures the memory-module cover to the computer base.
结论
Terrence15
于12/18/17注册
79,243 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,989篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 80
