跳转到主内容
Dell Inspiron 11z 1110 Display Assembly Replacement
你所需要的
  1. Dell Inspiron 11z 1110 Display Assembly Replacement, Dislodge the Mini-Card Antenna Cables: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
  2. Dell Inspiron 11z 1110 Display Assembly Replacement, Disconnecting the Display Cable: 步骤 2 中的图像 1,1
    • Disconnect the display cable and the camera cable from the system board connectors.
  3. Dell Inspiron 11z 1110 Display Assembly Replacement, Remove the Screws: 步骤 3 中的图像 1,1
    • Remove the two screws (one on each side) that secure the display assembly to the computer base.
  4. Dell Inspiron 11z 1110 Display Assembly Replacement, Lifting the Display Assembly: 步骤 4 中的图像 1,1
    • Lift the display assembly off the computer.
  5. Dell Inspiron 11z 1110 Display Assembly Replacement, Placing the Display Assembly: 步骤 5 中的图像 1,1
    • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
  6. Dell Inspiron 11z 1110 Display Assembly Replacement, Routing the Mini-Card Antenna Cables: 步骤 6 中的图像 1,1
    • Route the Mini-Card antenna cables through the routing guides.
结论
Terrence15
于12/18/17注册
78,592 声望
创作了441篇指南
团队
Informative Technologies Inc. Informative Technologies Inc. 的会员
Community
38 名成员
创作了1,982篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 223
