跳转到主内容
Dell Inspiron 1100 Wireless Card Replacement
你所需要的
  1. Dell Inspiron 1100 Wireless Card Replacement, Wireless Card: 步骤 1 中的图像 1,2 Dell Inspiron 1100 Wireless Card Replacement, Wireless Card: 步骤 1 中的图像 2,2
    • Unscrew the one Phillips #0 screw at the bottom of the panel and remove the panel.
    • The screw does not separate from the cover. Be sure the screw is completely unscrewed before using force to remove the cover.
  2. Dell Inspiron 1100 Wireless Card Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 1100 Wireless Card Replacement: 步骤 2 中的图像 2,2
    • Unscrew the two 3mm Phillips #0 screws located on the card.
    • Be careful, as these screws are easy to strip.
  3. Dell Inspiron 1100 Wireless Card Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 1100 Wireless Card Replacement: 步骤 3 中的图像 2,2
    • Pull the white plastic tab on top of the card straight up to remove the card.
    • This step requires some light force. Be sure the screws from the previous step have been removed.
  4. Dell Inspiron 1100 Wireless Card Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use blunt nose tweezers to remove the power cable from the wireless card.
    • Make sure the tweezers are only gripping the head of the power cable and not any part of the wireless card, as this may damage the card.
结论
团队
UMass Dartmouth, Team 3-3, Isaacson Fall 2016 UMass Dartmouth, Team 3-3, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S3G3
3 名成员
创作了9篇指南
2条评论
I believe that is a phone modem, not a wireless card. Might be wrong though.
George A. - 回复
i think your right as dell 1100 dont have a wifi slot only can use usb or pcmcia card
Conner Peden - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 641
