简介
In this guide, we will show you how to remove the Display Assembly.
你所需要的
Close the display.
From the back of the computer, remove the two M2.5 x 5-mm screws labeled "circle D."
Open the display assembly approximately 180 degrees, and support the display assembly so that it does not open past this position.
Pull straight up on the pull-tab that is attached to the display-feed flex cable to disconnect the cable from the system board.
即将完成!
结论
