跳转到主内容
Dell Inspiron 1100 CD Drive Replacement
你所需要的
  1. Dell Inspiron 1100 CD Drive Replacement, CD Drive: 步骤 1 中的图像 1,2 Dell Inspiron 1100 CD Drive Replacement, CD Drive: 步骤 1 中的图像 2,2
    • Unscrew the one 8mm Phillips #0 screw immediately below the RAM compartment and remove the panel.
    • This screw locks the CD Drive into place and must be completely removed before proceeding.
  2. Dell Inspiron 1100 CD Drive Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 1100 CD Drive Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 1100 CD Drive Replacement: 步骤 2 中的图像 3,3
    • Unscrew the one Phillips #0 screw at the bottom of the RAM compartment cover, and remove the RAM compartment cover.
    • The screw does not separate from the cover. Be careful when using force to remove the cover. Also be sure that the screw has been completely unscrewed.
  3. Dell Inspiron 1100 CD Drive Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 1100 CD Drive Replacement: 步骤 3 中的图像 2,2
    • Push and hold the switch inside the RAM compartment to the right.
    • This will cause the CD Drive to be slightly pushed out of its slot.
    • If the switch cannot be moved, check to make sure you have completed the first step in this guide.
  4. Dell Inspiron 1100 CD Drive Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 1100 CD Drive Replacement: 步骤 4 中的图像 2,2
    • While holding down the switch in the RAM compartment, pull out the CD Drive.
结论
团队
UMass Dartmouth, Team 3-3, Isaacson Fall 2016 UMass Dartmouth, Team 3-3, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S3G3
3 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 8
总计 393
