跳转到主内容
Dell Inspiron 11-3168 Wifi module Replacement
你所需要的
  1. Dell Inspiron 11-3168 Wifi module Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron 11-3168 Wifi module Replacement, Battery: 步骤 1 中的图像 2,2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
  2. Dell Inspiron 11-3168 Wifi module Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 11-3168 Wifi module Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 11-3168 Wifi module Replacement: 步骤 2 中的图像 3,3
    • Remove the bottom case of the laptop by gently prying along the seam with a plastic opening tool.
  3. Dell Inspiron 11-3168 Wifi module Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 11-3168 Wifi module Replacement: 步骤 3 中的图像 2,2
    • Remove the one 7.5mm screw that is holding the battery in place.
  4. Dell Inspiron 11-3168 Wifi module Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 11-3168 Wifi module Replacement: 步骤 4 中的图像 2,2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  5. Dell Inspiron 11-3168 Wifi module Replacement: 步骤 5 中的图像 1,3 Dell Inspiron 11-3168 Wifi module Replacement: 步骤 5 中的图像 2,3 Dell Inspiron 11-3168 Wifi module Replacement: 步骤 5 中的图像 3,3
    • Remove the battery.
  6. Dell Inspiron 11-3168 Wifi module Replacement, Wifi module: 步骤 6 中的图像 1,3 Dell Inspiron 11-3168 Wifi module Replacement, Wifi module: 步骤 6 中的图像 2,3 Dell Inspiron 11-3168 Wifi module Replacement, Wifi module: 步骤 6 中的图像 3,3
    • Use an opening tool or your fingers to release the clamps on both ends of the ribbon cable and lift away.
  7. Dell Inspiron 11-3168 Wifi module Replacement: 步骤 7 中的图像 1,3 Dell Inspiron 11-3168 Wifi module Replacement: 步骤 7 中的图像 2,3 Dell Inspiron 11-3168 Wifi module Replacement: 步骤 7 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the screw that is holding the WiFi module in place.
    • Remove the metal piece that covers the antenna cable connectors.
  8. Dell Inspiron 11-3168 Wifi module Replacement: 步骤 8 中的图像 1,3 Dell Inspiron 11-3168 Wifi module Replacement: 步骤 8 中的图像 2,3 Dell Inspiron 11-3168 Wifi module Replacement: 步骤 8 中的图像 3,3
    • To remove the WiFi module from the motherboard, slide it free of the socket connector.
  9. Dell Inspiron 11-3168 Wifi module Replacement: 步骤 9 中的图像 1,3 Dell Inspiron 11-3168 Wifi module Replacement: 步骤 9 中的图像 2,3 Dell Inspiron 11-3168 Wifi module Replacement: 步骤 9 中的图像 3,3
    • Disconnect both the black and the white wires from the WiFi module.
结论
To install the replacement module, start at step 4 and work your way backwards to step 1.
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 509
