跳转到主内容
Dell Inspiron 11-3168 Screen Replacement
你所需要的
  1. Dell Inspiron 11-3168 Screen Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron 11-3168 Screen Replacement, Battery: 步骤 1 中的图像 2,2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
  2. Dell Inspiron 11-3168 Screen Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 11-3168 Screen Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 11-3168 Screen Replacement: 步骤 2 中的图像 3,3
    • Remove the bottom case of the laptop by gently prying along the seam with a plastic opening tool.
  3. Dell Inspiron 11-3168 Screen Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 11-3168 Screen Replacement: 步骤 3 中的图像 2,2
    • Remove the one 7.5mm screw that is holding the battery in place.
  4. Dell Inspiron 11-3168 Screen Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 11-3168 Screen Replacement: 步骤 4 中的图像 2,2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  5. Dell Inspiron 11-3168 Screen Replacement: 步骤 5 中的图像 1,3 Dell Inspiron 11-3168 Screen Replacement: 步骤 5 中的图像 2,3 Dell Inspiron 11-3168 Screen Replacement: 步骤 5 中的图像 3,3
    • Remove the battery.
  6. Dell Inspiron 11-3168 Screen Replacement, Screen: 步骤 6 中的图像 1,3 Dell Inspiron 11-3168 Screen Replacement, Screen: 步骤 6 中的图像 2,3 Dell Inspiron 11-3168 Screen Replacement, Screen: 步骤 6 中的图像 3,3
    • Carefully flip the laptop over so that the top case is facing up.
    • Remove the top case of the laptop by gently prying along the seam with a plastic opening tool.
  7. Dell Inspiron 11-3168 Screen Replacement: 步骤 7 中的图像 1,3 Dell Inspiron 11-3168 Screen Replacement: 步骤 7 中的图像 2,3 Dell Inspiron 11-3168 Screen Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers to grip the tape that is holding down the display cable clip.
    • Gently unpeel the tape. This will release the clip that locks over the display connector socket.
    • Once unclipped, remove the display cable from the socket.
  8. Dell Inspiron 11-3168 Screen Replacement: 步骤 8 中的图像 1,3 Dell Inspiron 11-3168 Screen Replacement: 步骤 8 中的图像 2,3 Dell Inspiron 11-3168 Screen Replacement: 步骤 8 中的图像 3,3
    • Find the smaller ZIF connector. Using tweezers, carefully lift the black flap on the connector to release the ribbon cable.
  9. Dell Inspiron 11-3168 Screen Replacement: 步骤 9 中的图像 1,2 Dell Inspiron 11-3168 Screen Replacement: 步骤 9 中的图像 2,2
    • Disconnect the webcam module located at the top of the monitor.
  10. Dell Inspiron 11-3168 Screen Replacement: 步骤 10 中的图像 1,2 Dell Inspiron 11-3168 Screen Replacement: 步骤 10 中的图像 2,2
    • Lift and remove the display screen from the top case.
结论
另外一个人完成了本指南。
一条评论
how much did this display cost?
Ibrahim Ahmed Mohamed - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 750
