简介
This guide will show you how to replace the memory module of the Dell Inspiron 11-3168. Before starting, make sure both the laptop AC adapter and battery are disconnected prior to replacing any part or component.
Note: This guide does not apply to Celeron eMMC systems. These have the memory soldered to the board and require a motherboard replacement.
你所需要的
Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
Press down on the two latches on either side of the memory module.
Lift and remove the memory module.
另外一个人完成了本指南。
