跳转到主内容
Dell Inspiron 11-3164 Speaker Assembly Replacement
你所需要的
  1. Dell Inspiron 11-3164 Speaker Assembly Replacement, Speaker Assembly: 步骤 1 中的图像 1,2 Dell Inspiron 11-3164 Speaker Assembly Replacement, Speaker Assembly: 步骤 1 中的图像 2,2
    • Remove the eight 6mm back panel screws with your PH1 Phillips head screw driver bit.
    • Use your screw driver to remove the plastic cover in the center of the laptop.
    • Using a PH1 Phillips head screw driver bit remove the last 6mm screw.
  2. Dell Inspiron 11-3164 Speaker Assembly Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 11-3164 Speaker Assembly Replacement: 步骤 2 中的图像 2,2
    • Use your metal pry tool to pry around the laptop until the two pieces separate.
    • There will be a ribbon cable holding the two pieces together, be careful not to rip it out of it's socket.
    • Use your metal pry tool to release the connector.
  3. Dell Inspiron 11-3164 Speaker Assembly Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 11-3164 Speaker Assembly Replacement: 步骤 3 中的图像 2,2
    • Remove the speaker plug from it's socket.
    • Lift the speaker assembly from the case.
结论
团队
USF Tampa, Team S6-G4, Eyestone Spring 2018 USF Tampa, Team S6-G4, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S6G4
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 129
