简介
This guide will show you how to replace the USB Ports on your Dell Inspiron.
你所需要的
After taking off the back panel, you will see the battery located at the bottom of the computer system. It's black and is clearly labeled "dell battery".
Remove the two white power connectors on the bottom right of the motherboard by gently pulling on the tabs backward.
即将完成!
结论
另外一个人完成了本指南。
