跳转到主内容
Dell Inspiron 11-3152 Battery Replacement
你所需要的
  1. Dell Inspiron 11-3152 Battery Replacement, Back Panel: 步骤 1 中的图像 1,2 Dell Inspiron 11-3152 Battery Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Flip the computer over.
  2. Dell Inspiron 11-3152 Battery Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 11-3152 Battery Replacement: 步骤 2 中的图像 2,2
    • Remove all nine 5mm Phillips head screws from the back cover using #0 Phillips head.
  3. Dell Inspiron 11-3152 Battery Replacement: 步骤 3 中的图像 1,1
    • Gently use a spudger to pull the cover away from the rest of the laptop. The cover will come off after you use the tool on two or three sides.
  4. Dell Inspiron 11-3152 Battery Replacement, Battery: 步骤 4 中的图像 1,1
    • Make sure that the power is off.
    • After taking off the back panel, you will see the battery located at the bottom of the computer system. It's black and is clearly labeled "dell battery".
  5. Dell Inspiron 11-3152 Battery Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 11-3152 Battery Replacement: 步骤 5 中的图像 2,2
    • Locate the battery at the bottom of the computer and remove the four 3mm screws with a Phillips #0 head that hold the battery down.
  6. Dell Inspiron 11-3152 Battery Replacement: 步骤 6 中的图像 1,1
    • Remove the Solid State Drive wire from the battery clip by detaching the wire.
    • This can be done by gently pulling the connector away from the battery clip.
  7. Dell Inspiron 11-3152 Battery Replacement: 步骤 7 中的图像 1,1
    • Remove the battery from the computer system by gently lifting it from the side.
结论
另外一个人完成了本指南。
Matthew Duncan
于03/10/16注册
481 声望
创作了4篇指南
团队
UMass Dartmouth, Team 4-6, Catania Spring 2016 UMass Dartmouth, Team 4-6, Catania Spring 2016 的会员
UMASSD-CATANIA-S16S4G6
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 18
总计 781
