跳转到主内容
Dell Inspiron 11-3147 Replace the Battery Replacement
你所需要的
  1. Dell Inspiron 11-3147 Replace the Battery Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron 11-3147 Replace the Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Using a Philips Head #1 Screw Driver remove the nine .7mm screws holding the back cover in place.
    • The cover is held on with small plastic tabs. Starting from the back of the machine use your hands to gently prey the back cover from the machine and release these tabs. While a tool is not necessary a plastic plunger can be used to lift the first few tabs.
  2. Dell Inspiron 11-3147 Replace the Battery Replacement: 步骤 2 中的图像 1,1
    • The 4mm battery screws can be removed with a philips head #0 screw driver. All the screws that must be removed are shown in the attached pictures.
    • Place screws close by in a safe place such as a magnetic board or cup so they are ready and accounted for when you begin reassembly.
  3. Dell Inspiron 11-3147 Replace the Battery Replacement: 步骤 3 中的图像 1,1
    • Once the screws have been removed the battery may then be simply removed by hand and replaced.
结论
3等其他人完成本指南。
William Brum
于03/04/16注册
737 声望
创作了5篇指南
团队
UMass Dartmouth, Team 3-1, Bhusal Spring 2016 UMass Dartmouth, Team 3-1, Bhusal Spring 2016 的会员
UMASSD-BHUSAL-S16S3G1
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 17
总计 2,492
