跳转到主内容
Dell Inspiron 11-3147 RAM Replacement
你所需要的
  1. Dell Inspiron 11-3147 RAM Replacement, RAM: 步骤 1 中的图像 1,2 Dell Inspiron 11-3147 RAM Replacement, RAM: 步骤 1 中的图像 2,2
    • Using a Philips Head #1 Screw Driver remove the nine .7mm screws holding the back cover in place.
    • The cover is held on with small plastic tabs. Starting from the back of the machine use your hands to gently prey the back cover from the machine and release these tabs. While a tool is not necessary a plastic plunger can be used to lift the first few tabs.
  2. Dell Inspiron 11-3147 RAM Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 11-3147 RAM Replacement: 步骤 2 中的图像 2,2
    • Place finger nails on both of the little metal tabs that are located on shorter sides of the Ram board.
    • Pull tabs outward and away from the Ram card. This will detach the card from the computer and allow removal.
  3. Dell Inspiron 11-3147 RAM Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the RAM to ensure no other components get damaged.
    • Replace with a new RAM card the exact way it came out, with the the shiny metallic part of the card placed inside black insert as shown in the picture.
结论
4等其他人完成本指南。
William Brum
于03/04/16注册
737 声望
创作了5篇指南
团队
UMass Dartmouth, Team 3-1, Bhusal Spring 2016 UMass Dartmouth, Team 3-1, Bhusal Spring 2016 的会员
UMASSD-BHUSAL-S16S3G1
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 1,250
