跳转到主内容
Dell Inspiron 11-3147 CMOS Battery Replacement
你所需要的
  1. Dell Inspiron 11-3147 CMOS Battery Replacement, CMOS Battery: 步骤 1 中的图像 1,2 Dell Inspiron 11-3147 CMOS Battery Replacement, CMOS Battery: 步骤 1 中的图像 2,2
    • Using a plastic Philips Head #1 Screw Driver, remove the nine 7mm screws holding the back cover in place.
    • The cover is held on with small plastic tabs. Starting from the back of the machine use your hands to gently prey the back cover from the machine and release these tabs. While a tool is not necessary a plastic spudger can be used to lift the first few tabs.
  2. Dell Inspiron 11-3147 CMOS Battery Replacement: 步骤 2 中的图像 1,1
    • Using a plastic spudger, gently press under the battery to lift it up and out.
  3. Dell Inspiron 11-3147 CMOS Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the CMOS Battery
结论
William Brum
于03/04/16注册
737 声望
创作了5篇指南
团队
UMass Dartmouth, Team 3-1, Bhusal Spring 2016 UMass Dartmouth, Team 3-1, Bhusal Spring 2016 的会员
UMASSD-BHUSAL-S16S3G1
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 35
总计 3,004
