跳转到主内容
Dell Inspiron 11 i3147 Camera Replacement
你所需要的
  1. Dell Inspiron 11 i3147 Camera Replacement, Camera: 步骤 1 中的图像 1,1
    • Close the computer and turn it over, with the bottom of the computer facing up.
  2. Dell Inspiron 11 i3147 Camera Replacement: 步骤 2 中的图像 1,1
    • Remove the nine 7.6mm PH0 screws on the cover.
  3. Dell Inspiron 11 i3147 Camera Replacement: 步骤 3 中的图像 1,1
    • Use a plastic opening tool to remove the cover from the computer.
  4. Dell Inspiron 11 i3147 Camera Replacement: 步骤 4 中的图像 1,1
    • Remove the three 4.7mm PH0 screws that secure the battery to the computer.
  5. Dell Inspiron 11 i3147 Camera Replacement: 步骤 5 中的图像 1,1
    • Remove the hard drive cable from the battery.
  6. Dell Inspiron 11 i3147 Camera Replacement: 步骤 6 中的图像 1,1
    • Lift the battery from the keyboard.
  7. Dell Inspiron 11 i3147 Camera Replacement: 步骤 7 中的图像 1,1
    • Disconnect antenna cables.
  8. Dell Inspiron 11 i3147 Camera Replacement: 步骤 8 中的图像 1,1
    • Remove 2 4mm PH0 screws that connect display cable bracket to the system board.
    • Lift display cable bracket off the system board.
  9. Dell Inspiron 11 i3147 Camera Replacement: 步骤 9 中的图像 1,1
    • Use the pull tab to disconnect the display cable from the system board.
  10. Dell Inspiron 11 i3147 Camera Replacement: 步骤 10 中的图像 1,1
    • Pull the windows button board cable from the system board.
  11. Dell Inspiron 11 i3147 Camera Replacement: 步骤 11 中的图像 1,1
    • Remove the 2 5.6mm PH0 screws.
  12. Dell Inspiron 11 i3147 Camera Replacement: 步骤 12 中的图像 1,1
    • Separate the screen and body of the computer.
  13. Dell Inspiron 11 i3147 Camera Replacement: 步骤 13 中的图像 1,2 Dell Inspiron 11 i3147 Camera Replacement: 步骤 13 中的图像 2,2
    • Use a plastic opening tool to take the display panel assembly off the display back cover and antenna assembly. Start from the top.
    • Place display panel face down on a flat surface
  14. Dell Inspiron 11 i3147 Camera Replacement: 步骤 15 中的图像 1,1
    • Use a plastic opening tool to take the camera module off the display.
结论
Muhammad Erchid
于10/09/18注册
1,069 声望
创作了5篇指南
团队
USF Tampa, Team S1-G6, Leahy Fall 2018 USF Tampa, Team S1-G6, Leahy Fall 2018 的会员
USFT-LEAHY-F18S1G6
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 223
