简介
In this guide, we will show you how to remove and replace the Display Hinges.
你所需要的
Peel the tapes and remove the antenna cables from the routing guide on the hinge cover.
Remove the screws that secure the display hinges to the display back-cover and antenna assembly.
Lift the display hinges off the display back-cover and antenna assembly.
Align the screw holes on the NEW display hinges with the screw holes on the display back-cover and antenna assembly.
Replace the screws that secure the display hinges to the display back-cover and antenna assembly.
Route the antenna cables through the routing guide on the hinge cover and secure it in place.
