跳转到主内容
Dell Inspiron 11 3179 Display Assembly Replacement
你所需要的
  1. Dell Inspiron 11 3179 Display Assembly Replacement, Remove the Screw: 步骤 1 中的图像 1,1
  2. Dell Inspiron 11 3179 Display Assembly Replacement, Lifting the Display Cable: 步骤 2 中的图像 1,1
    • Lift the display-cable bracket off the system board.
  3. Dell Inspiron 11 3179 Display Assembly Replacement, Peeling the Tape: 步骤 3 中的图像 1,1
    • Peel off the tape to access the display cable.
  4. Dell Inspiron 11 3179 Display Assembly Replacement, Disconnecting the Display Cable: 步骤 4 中的图像 1,2 Dell Inspiron 11 3179 Display Assembly Replacement, Disconnecting the Display Cable: 步骤 4 中的图像 2,2
    • Open the latch and disconnect the display cable.
  5. Dell Inspiron 11 3179 Display Assembly Replacement, Disconnecting the Sensor-Board Cable: 步骤 5 中的图像 1,2 Dell Inspiron 11 3179 Display Assembly Replacement, Disconnecting the Sensor-Board Cable: 步骤 5 中的图像 2,2
    • Open the latch and disconnect the sensor-board cable from the I/O board.
  6. Dell Inspiron 11 3179 Display Assembly Replacement, Remove the Antenna Cable: 步骤 6 中的图像 1,2 Dell Inspiron 11 3179 Display Assembly Replacement, Remove the Antenna Cable: 步骤 6 中的图像 2,2
    • Remove the antenna cable from the routing guide on the right speaker.
  7. Dell Inspiron 11 3179 Display Assembly Replacement, Open the Latch: 步骤 7 中的图像 1,1
    • Open the latch and disconnect the I/O-board cable from the system board.
  8. Dell Inspiron 11 3179 Display Assembly Replacement, Peeling the Tapes: 步骤 8 中的图像 1,1
    • Peel the tapes off the display hinges.
  9. Dell Inspiron 11 3179 Display Assembly Replacement, Opening the Display: 步骤 9 中的图像 1,1
    • Turn the computer over and open the display as far as possible.
    • CAUTION: Place the computer on a soft and clean surface to avoid scratching the display.
  10. Dell Inspiron 11 3179 Display Assembly Replacement, Remove the Screws: 步骤 10 中的图像 1,1
    • Place the computer face down on a flat surface.
    • Remove the screws that secure the display assembly to the palm-rest and keyboard assembly.
  11. Dell Inspiron 11 3179 Display Assembly Replacement, Lifting the Display Assembly: 步骤 11 中的图像 1,2 Dell Inspiron 11 3179 Display Assembly Replacement, Lifting the Display Assembly: 步骤 11 中的图像 2,2
    • Lift the display assembly off the palm-rest and keyboard assembly.
  12. Dell Inspiron 11 3179 Display Assembly Replacement, Placing the Display Assembly: 步骤 12 中的图像 1,1
    • Place the NEW display assembly on the palm-rest and keyboard assembly.
  13. Dell Inspiron 11 3179 Display Assembly Replacement, Align the Screw Holes: 步骤 13 中的图像 1,1
    • Align the screw holes on the display hinges with the screw holes on the palm-rest and keyboard assembly.
  14. Dell Inspiron 11 3179 Display Assembly Replacement, Replace the Screws: 步骤 14 中的图像 1,1
    • Replace the screws that secure the display assembly to the palm-rest and keyboard assembly.
  15. Dell Inspiron 11 3179 Display Assembly Replacement, Sliding the I/O Board Cable: 步骤 15 中的图像 1,1
    • Turn the computer over and close the display.
    • Slide the I/O-board cable into its slot on the system board and press down the latch to secure the cable.
  16. Dell Inspiron 11 3179 Display Assembly Replacement, Routing the Antenna Cable: 步骤 16 中的图像 1,1
    • Route the antenna cable through its routing on the right speaker.
  17. Dell Inspiron 11 3179 Display Assembly Replacement, Sliding the Sensor-Board Cable: 步骤 17 中的图像 1,1
    • Slide the sensor-board cable into its slot on the I/O board and press down the latch to secure the cable.
  18. Dell Inspiron 11 3179 Display Assembly Replacement, Sliding the Display Cable: 步骤 18 中的图像 1,1
    • Slide the display cable into its slot on the system board and press down the latch to secure the cable.
  19. Dell Inspiron 11 3179 Display Assembly Replacement, Adhering the Tape: 步骤 19 中的图像 1,1
    • Adhere the tape on the display cable.
  20. Dell Inspiron 11 3179 Display Assembly Replacement, Align the Screw Hole: 步骤 20 中的图像 1,1
    • Align the screw hole on the display-cable bracket with the screw hole on the system board.
  21. Dell Inspiron 11 3179 Display Assembly Replacement, Replace the Screw: 步骤 21 中的图像 1,1
    • Replace the screw that secures the display-cable bracket to the system board.
结论
Terrence15
于12/18/17注册
79,243 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,989篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 271
