跳转到主内容
Dell Inspirion 15z-5523 Fan Replacement
你所需要的
  1. Dell Inspirion 15z-5523 Fan Replacement, Fan: 步骤 1 中的图像 1,1
    • First turn over your computer and remove all of the rubber stoppers on the back.
  2. Dell Inspirion 15z-5523 Fan Replacement: 步骤 2 中的图像 1,1
    • Then remove all the screws that were under the rubber stoppers.
  3. Dell Inspirion 15z-5523 Fan Replacement: 步骤 3 中的图像 1,1
    • Take the screw out of the back plate.
  4. Dell Inspirion 15z-5523 Fan Replacement: 步骤 4 中的图像 1,1
    • Remove back plate by grabbing and lifting up.
  5. Dell Inspirion 15z-5523 Fan Replacement: 步骤 5 中的图像 1,1
    • Remove CD port by pulling it straight out.
  6. Dell Inspirion 15z-5523 Fan Replacement: 步骤 6 中的图像 1,1
    • Remove the keyboard.
  7. Dell Inspirion 15z-5523 Fan Replacement: 步骤 7 中的图像 1,1
    • Take screw out of the surface below the keyboard and remove the top layer of the computer off of the base.
  8. Dell Inspirion 15z-5523 Fan Replacement: 步骤 8 中的图像 1,1
    • Remove the battery by unscrewing the 5 screws and pull straight out.
  9. Dell Inspirion 15z-5523 Fan Replacement: 步骤 9 中的图像 1,1
    • Remove the three screws from the hard drive and remove by pulling straight out.
  10. Dell Inspirion 15z-5523 Fan Replacement: 步骤 10 中的图像 1,2 Dell Inspirion 15z-5523 Fan Replacement: 步骤 10 中的图像 2,2
    • Unscrew motherboard and remove the two clips.
  11. Dell Inspirion 15z-5523 Fan Replacement: 步骤 11 中的图像 1,2 Dell Inspirion 15z-5523 Fan Replacement: 步骤 11 中的图像 2,2
    • Flip motherboard up, unscrew the three screws, and unclip the fan.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 824
