跳转到主内容
Dell Inspirion 15z-5523 Battery Replacement
你所需要的
  1. Dell Inspirion 15z-5523 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove all rubber stoppers and screw from the back of the laptop
  2. Dell Inspirion 15z-5523 Battery Replacement: 步骤 2 中的图像 1,2 Dell Inspirion 15z-5523 Battery Replacement: 步骤 2 中的图像 2,2
    • Detach keyboard from the laptop
    • Unscrew 4 screws on the metal frame (yellow circles)
    • Disconnect the 4 data connections (teal arrows)
  3. Dell Inspirion 15z-5523 Battery Replacement: 步骤 3 中的图像 1,1
    • Remove top computer frame
  4. Dell Inspirion 15z-5523 Battery Replacement: 步骤 4 中的图像 1,2 Dell Inspirion 15z-5523 Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the 5 screws that holding the old battery
    • Gently lift up battery and pull it out
结论
另外一个人完成了本指南。
2条评论
Excellent, Easy to follow and helpful graphics. Thanks
leonard russ - 回复
Hi Christian,
Would you happen to know what are the specs for the seven screws in the base of the Inspiron 15z 5523? Mine is exactly like the one in your post for replacing the battery. I lost mine when replacing the fan. Dell won’t help because the machine is out of warranty. Any ideas would be appreciated.
Thanks Christian.
David
David Sokal - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 30
总计 3,382
