跳转到主内容
加入维修社区 - 创建账户
Dell G3 15 3579 RAM Replacement
你所需要的
  1. Dell G3 15 3579  RAM Replacement, RAM: 步骤 1 中的图像 1,1
    • Make sure the laptop is off.
    • Lay the laptop on its front so the bottom is facing up.
  2. Dell G3 15 3579  RAM Replacement: 步骤 2 中的图像 1,1
    • Use the Phillips #0 to remove the eight screws (M2.5x6) on the bottom of the laptop.
    • Use the Phillips #0 to loosen the two captive screws (M2.5).
  3. Dell G3 15 3579  RAM Replacement: 步骤 3 中的图像 1,3 Dell G3 15 3579  RAM Replacement: 步骤 3 中的图像 2,3 Dell G3 15 3579  RAM Replacement: 步骤 3 中的图像 3,3
    • Use your hands or an opening tool to gently pry the bottom panel off, starting from the left hinge.
    • Continue prying from the bottom to the right side of the back panel and lift it off.
  4. Dell G3 15 3579  RAM Replacement: 步骤 4 中的图像 1,2 Dell G3 15 3579  RAM Replacement: 步骤 4 中的图像 2,2
    • Gently unplug the battery connecter from the motherboard.
  5. Dell G3 15 3579  RAM Replacement: 步骤 5 中的图像 1,3 Dell G3 15 3579  RAM Replacement: 步骤 5 中的图像 2,3 Dell G3 15 3579  RAM Replacement: 步骤 5 中的图像 3,3
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • After the RAM chip has popped up, pull it straight out of its socket.
  6. Dell G3 15 3579  RAM Replacement: 步骤 6 中的图像 1,2 Dell G3 15 3579  RAM Replacement: 步骤 6 中的图像 2,2
    • Gently align the new RAM with the tab on the slot.
    • Then slide it firmly into the slot at an angle and press the RAM down until it clicks into place.
    • If you do not hear the click, remove the RAM and reinstall it.
  7. Dell G3 15 3579  RAM Replacement: 步骤 7 中的图像 1,1
    • Align the bottom cover with the slots of the laptop and snap it into place.
    • Tighten the two captive screws (M2.5) to secure the bottom cover.
    • Replace the eight screws (M2.5x6) to secure the bottom cover.
结论
2等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 78
总计 5,782
