当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Locate the two holes on the bottom of the monitor.
Insert a plastic opening tool or spudger into the holes and gently pry the plastic apart along the groove.
This task is much easier if two people pry simultaneously at each hole.
Continue prying along the entire edge of the monitor.
When finished prying, the plastic will partially fall away from the rest of the monitor.
Do not try to fully remove the front frame yet. The frame is still attached to the buttons.
While holding the frames together, carefully flip the monitor over so it faces screen down.
Gently lift and remove remove the rear case from the monitor.
Locate the green interface button board.
Remove the three 9.71 mm Phillips #2 screws holding the interface button board to the display bezel.
Lift the monitor interior away from the front cover.
Behind the front panel of the plastic cover lies the button strip.
Remove the buttons by gently pulling up on the strip.
You may have to pry the plastic strip up with a prying tool or spudger to remove it.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
