跳转到主内容
Dell E193FPc Interface Buttons Replacement
你所需要的
  1. Dell E193FPc Interface Buttons Replacement, Stand: 步骤 1 中的图像 1,1
    • Lay the monitor screen-down so the back screws are exposed.
    • Remove the four 11.9 mm Phillips #2 screws securing the stand to the back of the monitor.
  2. Dell E193FPc Interface Buttons Replacement: 步骤 2 中的图像 1,1
    • Gently lift and pull away the stand at a slight angle away from the monitor.
  3. Dell E193FPc Interface Buttons Replacement, Display Bezel: 步骤 3 中的图像 1,2 Dell E193FPc Interface Buttons Replacement, Display Bezel: 步骤 3 中的图像 2,2
    • Locate the two holes on the bottom of the monitor.
    • Insert a plastic opening tool or spudger into the holes and gently pry the plastic apart along the groove.
    • This task is much easier if two people pry simultaneously at each hole.
    • Continue prying along the entire edge of the monitor.
  4. Dell E193FPc Interface Buttons Replacement: 步骤 4 中的图像 1,2 Dell E193FPc Interface Buttons Replacement: 步骤 4 中的图像 2,2
    • When finished prying, the plastic will partially fall away from the rest of the monitor.
    • Do not try to fully remove the front frame yet. The frame is still attached to the buttons.
    • While holding the frames together, carefully flip the monitor over so it faces screen down.
    • Gently lift and remove remove the rear case from the monitor.
  5. Dell E193FPc Interface Buttons Replacement: 步骤 5 中的图像 1,3 Dell E193FPc Interface Buttons Replacement: 步骤 5 中的图像 2,3 Dell E193FPc Interface Buttons Replacement: 步骤 5 中的图像 3,3
    • Locate the green interface button board.
    • Remove the three 9.71 mm Phillips #2 screws holding the interface button board to the display bezel.
    • Lift the monitor interior away from the front cover.
  6. Dell E193FPc Interface Buttons Replacement, Interface Buttons: 步骤 6 中的图像 1,1
    • Behind the front panel of the plastic cover lies the button strip.
    • Remove the buttons by gently pulling up on the strip.
    • You may have to pry the plastic strip up with a prying tool or spudger to remove it.
结论
另外一个人完成了本指南。
Charley Grove
于10/10/11注册
98 声望
撰写一个指南
团队
Cal Poly, Team 5-36, Amido Fall 2011 Cal Poly, Team 5-36, Amido Fall 2011 的会员
CPSU-AMIDO-F11S5G36
4 名成员
创作了12篇指南
一条评论
and then…?! you cant buy replacement buttons!! so now what?!
Sarah Barnes - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 2,170
