跳转到主内容
Dell E193FPc Display Bezel Replacement
你所需要的
  1. Dell E193FPc Display Bezel Replacement, Stand: 步骤 1 中的图像 1,1
    • Lay the monitor screen-down so the back screws are exposed.
    • Remove the four 11.9 mm Phillips #2 screws securing the stand to the back of the monitor.
  2. Dell E193FPc Display Bezel Replacement: 步骤 2 中的图像 1,1
    • Gently lift and pull away the stand at a slight angle away from the monitor.
  3. Dell E193FPc Display Bezel Replacement, Display Bezel: 步骤 3 中的图像 1,2 Dell E193FPc Display Bezel Replacement, Display Bezel: 步骤 3 中的图像 2,2
    • Locate the two holes on the bottom of the monitor.
    • Insert a plastic opening tool or spudger into the holes and gently pry the plastic apart along the groove.
    • This task is much easier if two people pry simultaneously at each hole.
    • Continue prying along the entire edge of the monitor.
  4. Dell E193FPc Display Bezel Replacement: 步骤 4 中的图像 1,2 Dell E193FPc Display Bezel Replacement: 步骤 4 中的图像 2,2
    • When finished prying, the plastic will partially fall away from the rest of the monitor.
    • Do not try to fully remove the front frame yet. The frame is still attached to the buttons.
    • While holding the frames together, carefully flip the monitor over so it faces screen down.
    • Gently lift and remove remove the rear case from the monitor.
  5. Dell E193FPc Display Bezel Replacement: 步骤 5 中的图像 1,3 Dell E193FPc Display Bezel Replacement: 步骤 5 中的图像 2,3 Dell E193FPc Display Bezel Replacement: 步骤 5 中的图像 3,3
    • Locate the green interface button board.
    • Remove the three 9.71 mm Phillips #2 screws holding the interface button board to the display bezel.
    • Lift the monitor interior away from the front cover.
结论
5等其他人完成本指南。
Mackenzie Keane
于10/04/11注册
514 声望
创作了5篇指南
团队
Cal Poly, Team 5-36, Amido Fall 2011 Cal Poly, Team 5-36, Amido Fall 2011 的会员
CPSU-AMIDO-F11S5G36
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 4,315
