跳转到主内容
Dell Dimension 4600 Video Card Replacement
你所需要的
  1. Dell Dimension 4600 Video Card Replacement, Side Panel: 步骤 1 中的图像 1,1
    • Locate the case cover latch on the back of the computer.
  2. Dell Dimension 4600 Video Card Replacement: 步骤 2 中的图像 1,1
    • Using your index finger, slide and hold the cover latch down.
    • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
  3. Dell Dimension 4600 Video Card Replacement: 步骤 3 中的图像 1,1
    • Grab the edge of the panel and slide it away from the case until it is removed.
  4. Dell Dimension 4600 Video Card Replacement, Video Card: 步骤 4 中的图像 1,1
    • Lay the computer flat so that you are looking down on all of the components.
  5. Dell Dimension 4600 Video Card Replacement: 步骤 5 中的图像 1,1
    • Locate the Video Card and the screw attached to the Video Card as shown in the picture.
  6. Dell Dimension 4600 Video Card Replacement: 步骤 6 中的图像 1,1
    • Remove the 8.9 mm screw by using a Phillips #2 screw-driver.
  7. Dell Dimension 4600 Video Card Replacement: 步骤 7 中的图像 1,1
    • Push down on the green clip located by the bottom right corner of the video card while simultaneously pulling the card up with your other hand.
  8. Dell Dimension 4600 Video Card Replacement: 步骤 8 中的图像 1,1
    • Pull the remainder of the card up and out of it's slot.
结论
9等其他人完成本指南。
Arvind
于10/12/11注册
395 声望
创作了2篇指南
团队
Cal Poly, Team 6-10, Regan Fall 2011 Cal Poly, Team 6-10, Regan Fall 2011 的会员
CPSU-REGAN-F11S6G10
4 名成员
创作了11篇指南
2条评论
I have a question - My dell dimension 4600 has lines going down the screen, ive tried 3 different monitors, reinstalling windows (reinstalling would have lines going down the screen, after installing all programs the system freezes up with lines going down the screen nothing else) ive tried system restore can someone tell me whats going on?
Don't hurt the chickens - 回复
That sounds like either a GPU failure or internal Graphics failure. Have you checked thermal paste?
William Morgan - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 7,523
