跳转到主内容
Dell Dimension 4600 Side Panel Replacement
  1. Dell Dimension 4600 Side Panel Replacement, Side Panel: 步骤 1 中的图像 1,1
    • Locate the case cover latch on the back of the computer.
  2. Dell Dimension 4600 Side Panel Replacement: 步骤 2 中的图像 1,1
    • Using your index finger, slide and hold the cover latch down.
    • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
  3. Dell Dimension 4600 Side Panel Replacement: 步骤 3 中的图像 1,1
    • Grab the edge of the panel and slide it away from the case until it is removed.
结论
10等其他人完成本指南。
Daniel Crawford
于10/10/11注册
1,021 声望
创作了2篇指南
团队
Cal Poly, Team 6-10, Regan Fall 2011 Cal Poly, Team 6-10, Regan Fall 2011 的会员
CPSU-REGAN-F11S6G10
4 名成员
创作了11篇指南
2条评论
I can't get the panel off
Diego Vega - 回复
Thanks, worked perfectly, very much appreciated!
Bodhi Goforth - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 31
总计 21,808
