跳转到主内容
Dell Dimension 4600 RAM Replacement
你所需要的
  1. Dell Dimension 4600 RAM Replacement, Side Panel: 步骤 1 中的图像 1,1
    • Locate the case cover latch on the back of the computer.
  2. Dell Dimension 4600 RAM Replacement: 步骤 2 中的图像 1,1
    • Using your index finger, slide and hold the cover latch down.
    • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
  3. Dell Dimension 4600 RAM Replacement: 步骤 3 中的图像 1,1
    • Grab the edge of the panel and slide it away from the case until it is removed.
  4. Dell Dimension 4600 RAM Replacement, RAM: 步骤 4 中的图像 1,1
    • Lay the computer flat on its side so that you are looking down on all of the components.
    • Locate the RAM modules on the motherboard.
  5. Dell Dimension 4600 RAM Replacement: 步骤 5 中的图像 1,2 Dell Dimension 4600 RAM Replacement: 步骤 5 中的图像 2,2
    • Locate the white or black tabs holding the RAM module in place.
    • Place your index finger on the tab and firmly press down. The tab should release and the RAM module should be slightly raised.
    • Repeat this for the tab on the other side of the RAM module.
    • Repeat this step for each RAM module.
  6. Dell Dimension 4600 RAM Replacement: 步骤 6 中的图像 1,2 Dell Dimension 4600 RAM Replacement: 步骤 6 中的图像 2,2
    • Grasp the RAM module and firmly pull upwards until it is released from its slot.
结论
13等其他人完成本指南。
Daniel Crawford
于10/10/11注册
1,021 声望
创作了2篇指南
团队
Cal Poly, Team 6-10, Regan Fall 2011 Cal Poly, Team 6-10, Regan Fall 2011 的会员
CPSU-REGAN-F11S6G10
4 名成员
创作了11篇指南
一条评论
Would be great if the DIMM slots were explained (numbering) as to which are populated for dual channel, etc.
MJfromMD - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 10,175
