跳转到主内容
加入维修社区 - 创建账户
Dell Dimension 4600 Optical Drive Replacement
你所需要的
  1. Dell Dimension 4600 Optical Drive Replacement, Side Panel: 步骤 1 中的图像 1,1
    • Locate the case cover latch on the back of the computer.
    询问修复机器人
    添加评论
  2. Dell Dimension 4600 Optical Drive Replacement: 步骤 2 中的图像 1,1
    • Using your index finger, slide and hold the cover latch down.
    • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
    询问修复机器人
    添加评论
  3. Dell Dimension 4600 Optical Drive Replacement: 步骤 3 中的图像 1,1
    • Grab the edge of the panel and slide it away from the case until it is removed.
    询问修复机器人
    添加评论
  4. Dell Dimension 4600 Optical Drive Replacement, Optical Drive: 步骤 4 中的图像 1,1
    • Locate the Optical Drive by finding it externally on the case.
    询问修复机器人
    添加评论
  5. Dell Dimension 4600 Optical Drive Replacement: 步骤 5 中的图像 1,2 Dell Dimension 4600 Optical Drive Replacement: 步骤 5 中的图像 2,2
    • Press and hold the three levers located behind the front panel.
    • While holding the levers down, swing open the front panel.
    询问修复机器人
    添加评论
  6. Dell Dimension 4600 Optical Drive Replacement: 步骤 6 中的图像 1,1
    • Swing the front of the case open until it separates from the main case.
    询问修复机器人
    添加评论
  7. Dell Dimension 4600 Optical Drive Replacement: 步骤 7 中的图像 1,3 Dell Dimension 4600 Optical Drive Replacement: 步骤 7 中的图像 2,3 Dell Dimension 4600 Optical Drive Replacement: 步骤 7 中的图像 3,3
    • Lay the computer flat on it's side so that you are looking down on all of the components.
    • Locate the Drive 1 cable and where it is connected to the motherboard.
    询问修复机器人
    添加评论
  8. Dell Dimension 4600 Optical Drive Replacement: 步骤 8 中的图像 1,1
    • Grasp the end of the Drive 1 cable connected to the motherboard and firmly pull upwards until it is removed.
    询问修复机器人
    添加评论
  9. Dell Dimension 4600 Optical Drive Replacement: 步骤 9 中的图像 1,2 Dell Dimension 4600 Optical Drive Replacement: 步骤 9 中的图像 2,2
    • Locate the end of the Drive 1 cable connected to the optical drive.
    • Grasp the cable and pull firmly to disconnect it from the optical drive.
    询问修复机器人
    添加评论
  10. Dell Dimension 4600 Optical Drive Replacement: 步骤 10 中的图像 1,2 Dell Dimension 4600 Optical Drive Replacement: 步骤 10 中的图像 2,2
    • Locate the screw on the optical drive.
    • Remove the 7.7 mm screw by using a Phillips #2 screw-driver.
    询问修复机器人
    添加评论
  11. Dell Dimension 4600 Optical Drive Replacement: 步骤 11 中的图像 1,1
    • Remove the optical drive by sliding it out of the front of the case.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
13等其他人完成本指南。
Eugene
于10/12/11注册
216 声望
撰写一个指南
团队
Cal Poly, Team 6-10, Regan Fall 2011 Cal Poly, Team 6-10, Regan Fall 2011 的会员
CPSU-REGAN-F11S6G10
4 名成员
创作了11篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 47
总计 7,289
