简介
This guide shows you how to replace the LCD panel for a Dell Chromebook 3180.
你所需要的
Open the chromebook until its completely flat on the table
Remove both the left and right hinge caps
Remove a total of 4 screws. One in each corner.
Use a plastic pry tool or blade and start in the top left corner or first left plastic ridge.
Lift up the LCD screen from within the LCD assembly frame.
On the back of the LCD screen, remove the tape and LCD connector
Attach the LCD connector
re-apply the tape to the LCD connector
Set the new LCD screen into the LCD assembly frame while matching up the screw ports in each corner
When installing the LCD bezel, look for the plastic hinge outlines on each side and match them up with the metal hinges on the chromebook.
Snap the LCD bezel in place until it is flush with the entire LCD assembly
另外一个人完成了本指南。
