简介
This guide will show you how to replace the audio board for your Dell Chromebook 3180.
配件
无需配件。
  1. Remove the 7 screws from the back cover with a Phillips #0 screwdriver Once all 7 screws have been removed, you can start to pry apart the back cover with your Plastic Blade or your fingers. (See pic)
    • Remove the 7 screws from the back cover with a Phillips #0 screwdriver
    • Once all 7 screws have been removed, you can start to pry apart the back cover with your Plastic Blade or your fingers. (See pic)
    • Disconnect the audio board data cable from the motherboard.
    • Using a Philips #0 , remove the 1 screw from the audioboard.
  2. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
    • Remove audio board from the packaging. You may not need the new data cable which is included in the packaging. You can always use the old data cable from the old audio board.
    • Look on both sides of the data cable. Peel off the white double sided sticky paper so that the adhesive can stick to the chromebook base. This will help keep the data cable secure.
    • Insert the new audio board at angle so that the headphone port can fit correctly into the palmrest.
    • Connect the audio board data cable to the motherboard. You can always use the old data cable instead of the new data cable that was included in the packaging.
结论
另外一个人完成了本指南。
Jon
于2013年08月18日注册
2,761 信誉积分
创作了18篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 5
总计 121
