跳转到主内容
Dell Chromebook 3110 Battery Replacement
你所需要的
  1. Dell Chromebook 3110 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Set the laptop upside down on a clean work space.
  2. Dell Chromebook 3110 Battery Replacement: 步骤 2 中的图像 1,1
    • Remove nine 4 mm screws from the back cover of the laptop using a Phillips #00 screwdriver.
  3. Dell Chromebook 3110 Battery Replacement: 步骤 3 中的图像 1,1
    • Using an opening pick and a plastic opening tool, begin to separate the back cover from the laptop.
    • Using your hands, fully remove the back cover.
  4. Dell Chromebook 3110 Battery Replacement: 步骤 4 中的图像 1,1
    • Unplug the battery from the motherboard by gently pulling on the cable header from the motherboard toward the battery.
    • Using the Phillips #0 screwdriver, remove the three screws from the battery.
  5. Dell Chromebook 3110 Battery Replacement: 步骤 5 中的图像 1,1
    • Carefully lift the battery out of the laptop.
结论
另外一个人完成了本指南。
Anna K Tomko
于02/24/23注册
136 声望
撰写一个指南
团队
Marist, Team 1-6, Chaterdon Spring 2023 Marist, Team 1-6, Chaterdon Spring 2023 的会员
MARS-CHATERDON-S23S1G6
2 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 26
总计 230
