简介
The mouse pad often suffers the most wear and tear from daily use. If the mouse pad becomes frozen or non responsive, it can be replaced using this guide.
你所需要的
The battery must be removed to access the mouse pad. To remove the battery, undo the two, 2mm screws located on each side.
Once all four screws are removed, unplug the battery connection cable by hand to disconnect the battery from the motherboard.
To remove the battery, lift up on one side to get you fingers underneath and lift away.
Congratulations! You have successfully removed the mouse pad on your Dell Chromebook 13-7310. To reassemble your device, follow these instructions in reverse order.
